Just thought I’d try and see if we could start a wheel fitment thread, similar to the ones most of you have seen on nico and zilvia. Lots of nice setups seen this season in the Recent Pic thread and since people are posting their setups, why not make one of these so that we have a reference thread for setups (mostly dd) that SON people have had.
Main Idea
-Hopefully we can all keep this place as a NON-DISCUSSION PICTURE REFERENCE ONLY sorta deal.
-Let’s avoid stock setups. There’s enough stock 240 pictures out there.
-If there’s a small amount of work done (but barely noticeable), as long as it still relates to the thread topic and is wheel fitment related mods, please post.
-*Please only post your setup again if something has changed.
And in order to be fair, since it’s going to happen no matter what, let’s make a deal:
If you want to add something else to the thread, or just say something, be sure to POST A PICTURE of some wheel setup, and briefly post what it is (ie. 18x10-15 is good enough). At least that way you’re still posting with a setup reference.
TEMPLATE (Pictures go whereever you want)
WHEELS (1, 2, 3 = Required)
- Make and Model: *Note if different FR/RR (ie. FR - … RR - …)
- Size: *Note if different FR/RR
- Offset: *Note if different FR/RR
- Spacer, if used: *Note if different FR/RR
- Clearance: caliper and coilover clearance issues from personal experience, if applicable
TIRES (All Required)
6) Make and Model: *Note if different FR/RR (ie. FR - … RR - …)
7) Size: *Note if different FR/RR
8) Pressure: *Note if different FR/RR
SUSPENSION (All Optional)
9) Coilovers:
10) Dampening Level, if applicable:
11) Arms:
12) Other: Alignment and fitment related mods only please
ALIGNMENT (All Optional)
13) Camber: *Note if different FR/RR (ie. FR: … RR: …)
14) Castor: *Note if different FR/RR (ie. FR: … RR: …)
15) Toe: *Note if different FR/RR (ie. FR: … RR: …)
BODY (If Applicable)
16) Roll: (FR, RR, FR+RR)
17) Pull: (FR, RR, FR+RR)
18) Fenders, if applicable: (specify width)
Let me know if I’ve missed anything. Once again, please try to keep the discussion to a minimum. Please be prepared when posting and make sure you have pics and a decent amount of info to include.
