need s13 motor mounts… nismos are half price of oem mounts
and anything aftermarket will give me a concussion…
anyone?
got mine from ebay
grrr id like them within this week
I got mine within 5 days, tranny and motor mounts for 170 i think
something tells me varun may have them in stock
try him
Go aftermarket
got my 3pc set from frsport.com $230…well worth it
arent nismo ones aftermarket?
Nismo is more like, reinforced oem?
OEM
NISMO
Awesome $50 wickedness
I had nismo mounts in my old old car. They were awesome. They are better then oem. Really stiff though. I got mine from nissan dealership within about a week. Varun should have em.
weld your shit stock mounts , put thick metal in between the spaces on either end and weld , comes out a solid gangster mount !!!
I am not looking for solid or even anything stiff…
its annoying as fuck hearing every panel and dash piece in your car vibrate…
i think nissan still has access to them, parts guys r usually pricks tho…
thanks all
Duh, just remove all your panels…
I second the Nissan parts guys are pr*cks. I got my Megan set for 220 from varun shipped. I think the nismos were another 30 bucks. The megans and the nismos are stock mounts with stiffer rubber. As for the vibration I’ve heard both sides of the story, mine are installed but I haven’t started the car yet, will post a full review once I get up and running
Nismo’s raise your motor a half inch, fyi.
I got my OEM ones through pur for 70 bucks… No tranny mount, just the two engine mounts. OEM nissan stuff.
Mind you that was at a decent discount.
Hockey Pucks…
3m urethane window weld is pretty awesome, I think 30 bucks for the tube
I got my NISMO set from BING a couple of years ago … they came in quick time … ask him … They did raise the motor up about 1/2" but you can adjust that with the mounts themselves. To get close to your worn out factory mount height. Very impressed with the feel and stiffness… did custom exhaust work at the same time so I can’t really comment on if they made things louder or not.
I got the Megan mounts from Varun.
I hated them. That much vibration should not be transmitted to the cabin for any good reason…
The new exhaust also did not help…so much drone. I had to wear earplugs on the highway for long drives.
Also forget about SQL altogether if you have a decent audio system. You won’t hear shit in terms of detail.
