Searched up, but seems that a lot of places don’t exist anymore… Any you guys know of?
Cherry Turbos
353 Sunset Drive
St Thomas, Ontario
N5R 3C6
(519) 633-7842
In Canada  1 (800) 387-3089 o
Cherry Turbos is a high quality Turbo Rebuilding facility with 10 years of rebuilding experience. We can build you a hybrid turbo or a blue printed stock turbo and anything in between.
Seems that you didnt search very hard, as this topic has been covered on a NUMBER of occasions.
ty, I just wanted some updated opinions
^ what turbo do you plan on rebuilding?
t25
cherry turbo is awesome
Dont bother with the t25. Spend that money and get mint T28 or another T25.
if u want something more serious i can give u my t3 super 60 and u can have it rebuild by cherry turbo. the turbo needs a major rebuild. i have it all apart but just don’t have a rebuild kit. its going to need a sleeve at the compressor back plate. but the cherry guy will do that for u. come oshawa get it. 25$$ for u. bought it for 50$$
I think it was discussed in other threads that rebuilding most cheap smaller turbo’s wasn’t really worth it since the cost to rebuild was high, so I can guarantee it won’t be worth to rebuild a t25 as they only go for about 150 bucks
Just make absolute sure the turbo you buy isn’t blown!
alright, thanks for the insight, I should have searched more, sorry 'bout that!
t25 rebuild is generally $400 from a shop. Closer to 120 if you do it yourself.
After swapping so many of these t25’s over the past 2 years, its not worth it, unless u plan on keeping the little turbo at a stockish boost and don’t plan really driving it hard.
If you do plan on driving your car hard, then save up and get a newer turbo. Something that can handle higher boost levels and won’t destroy it self. When you factor in the gaskets every time a turbo fails, the time you spend swapping it and all that shit, sticking with the stock t25 is a bigger hardship on the longer run.
Cheapest alternative is a gently used t28. More expensive is a used gt2871r.
Herman @ cherry turbos is great. Just ask him to build you a new one. I brought him a turbo to rebuild and ended up replacing for cheaper and got a better product. He works out of his house and turn around is a few days
