Harbor freight sells HVLP guns for like $40 and I got 2 bright as hell shop lights if you wanna borrow them.
can someone clear up a few things about wet-sanding?
what grits do u use?
should a sanding block be used or just paper in hand?
If block should be used, what size sanding block do u recommend?
[quote=“boardjnky4,post:62,topic:31450"”]
[/quote]
for wetsandin a regular paintjob or a rustolieum roller paint job?
1000 for the big stuff, finner (1500 / 2000) for small orange peel and for making it easier to buff
ALWAYS USE A BLOCK FOR ANY SANDING YOU DO ON A PANEL U WANT STRAIGHT
get a foam snading pa for the big areas, short sections of paint sticks are good for tight areas
[quote=“speedped79,post:63,topic:31450"”]
[/quote]
both
[quote=“HotRodKid,post:64,topic:31450"”]
[/quote]
I have a harbor freight sanding block. one of the long ones that are not flexible. Will that do the trick?
get a foam block, and start with 1000 grit for between coats. see how the last coat lays. you may be able to get away with 1500, 2000, and then buffing
[quote=“boardjnky4,post:65,topic:31450"”]
both
[/quote]
the soft ones are much better for wet sanding paint you dont want to screw up
its REALY hard to get the edge of a soft block to dig in and ruin paint
[quote=“HotRodKid,post:68,topic:31450"”]
[/quote]
gotcha
suuuuuuuuubscribed.
[quote=“93dx–hatch,post:58,topic:31450"”]
do a search on honda tech before you start
[/quote]
hmm, their cars were MEH at best. But they are also poor honda kids who probably don’t do anything right… I might use the HVLP gun, but it just seems like so much more mess…
[quote=“newman,post:71,topic:31450"”]
[/quote]
consider that you are going to simply beat this car and then turn it around for a quick sale.
:gotme:
