On my 93 hatch, the rear washer fluid works perfect, you can hear the pump run and fluid comes out. However, the front washers do not work at all. The pump doesn’t run, but the wipers do 3 passes. I haven’t taken a good look under the hood yet, as I’m not too familiar with the car and its not high on the priority list. I was just wondering if anyone had this happen before. I didn’t see any kinked lines or anything, but I dont know a whole lot.
Also, the dimmer switch on this car quit working on me. Do I have to take off the dash pad to get at this switch? I assume I will have to wire in a resistor in place of the switch, but does anyone know what ohm resistor I will need for the brightest setting? Or if someone has a spare dimmer switch kicking around…
(quit working when I turned the dimmer switch down, figures)
I sprayed some industrial strength contact cleaner into the dash around the button, which was a mistake because it at the plastic around the switch. Now the plastic set and it won’t even move.
