A LOT of $$ later along with many busted up knuckles, its finally DONE. ugh im so glad this is done and over with, all i have to do is tidy up a few things and hook up my HKS DLI II. Car ran for its first time tonight after a solid month of being torn down while waiting for parts to come in.
what ive done for this spring:
buschur 35r kit
buschur race FMIC (not on the car)
painted VC
painted headlights (jdm)
painted stock enkeis black wrapped in nitto drag radials
mini battery kit w/ all new IC piping
honestly not sure, i plan on having 2 tunes. for the street ill be running sunoco 100 oct. for the track ill be running mikes 112. similar setup as emerys evo that he had last year
Nice man, glad to see some winter projects are progressing. Most people I know are just “starting” this week or next. I know a bunch of us will be scrambling to get ready for “spring”. Hell spring solstice is only ~40 days away.
Not exactly, he had the hafe manifold and a t3 hotside. The ems makes a big difference too.
I have two suggestions. Get rid of the forge for an evo mr bov and get rid of the solid up rad pipe unless you use more silicone on the motor side. I doubt you have the mitsu ralliart mounts so the motor will be rocking a ton and will probably cause a coolant leak.
Other wise it should be a blast, I know you’ll enjoy it.
