WTB:NON-HICAS Power Steering Pump
As the title states, removing the HICAS from my car.
So just disable the HICAS section of your pump.
just do that its easier that gettin a new pump, resivior, P/S bracket and line.
i just did that to mine, re move the pump and there are 4 bolts in the back, remove those and there are a bunch of tiny metal squares that fall out. remove those then tighten the bolts all back up. then plug off where the hicas line goes. also plug off the hicas line off the res.
did you remove the HICAS solenoid and lines to save weight, then cap off the ends? supposedly these things do have some weight on them?
im removing all my lines and junk when i get my lock bar,or if i can find a subframe for cheap. extra useless weight is bunk. throw that shit in the trash.
ya i picked up a kazama lock bar, removed the solenoid and everything.
