WTBBB: KA clutch assembly !help
My clutch is about to go it doesnt even spring back nemore goto lift it up with my foot each time and when i press it all the way down it feels like it is not even pressed in cuz i can bearly put it in 1st but neways i need the new clutch ,release bearing and the plate… not looking to spend a lot on it but i do want to upgrade from my piece of shit i had bfr. Im looking to get this done on monday so i need to collect the parts over the weekend if any1 has anything i can buy plz let me know or any opinions on what i should do/buy will be appreciated (i guess the best i can get for 100-250$)
thanks
Have you considered that the seal in your slave cylinder might be gone? Usually when it goes your pedal won’t return to normal height, and when you depress the pedal it barely releases the clutch because most of the fluid is being lost.
I’d double check before you go spending all sorts of cash on a clutch.
