"GAMER fed up with his new Xbox 360 crashing every 20 minutes has fixed the problem by raising the power supply off the ground with some string.
Dan, from Duluth, or ‘goldeneyemaster’ as he is known, told the game spot forum here that he thinks the main reason that the xBox 360 freezes is because the power supply overheats. The solution is to lift the power supply off the floor and allow the air to circulate better around it."
$10 says around 25% or more. They should do a serious poll on that. I’ve never set a system on a rug… and if I had to I would at least sit it on a box or something. Have never had a problem.
Had my 360 freeze up tonight while i was playing, so after reading this thread and getting paranoid i lifted my power supply up off the ground and leaned it up on its side at an angle. Played for a few hours after with no troubles. :gotme:
