sure buddy
I’m just gona add to this and say that this is true but only for the 26mm version of z32 brakes.
The 30mm version will not clear any stock s13 wheel unless u use a small spacer.
m running 8mm or 5/16 inch spacer in the rear I would not go more then this. I know some people say 5mm is max for stock studs but I haven’t had a problem yet, so far about 10 000 street kms on them and 2 track days. Hope this helps.
i priced out the aluminum 30mm calipers re-built through one of my suppliers at 90 bucks a piece
if you can get those rebuilt calipers for 90$ each i’ll take both fronts.
i get them at 90. don’t sell them at 90
no nissan calipers are made by nissan… so you technically are right
would anyone be able to post detailed pictures of their brake conversion on an s13 for me? would be greatly appreciated.
