1995 Miata "R" and much more
FS: 1995 Miata, 92000 miles. 100% converted to “R” Package (lightest possible factory configuation with Torsen diff, also has stiffer rear springs and lower ride height.) Car came from North Carolina, so no Buffalo winters. Currently garage-kept and only driven to and from events.
Includes:
  • Custom-valved Bilstein shocks built by FatCat Motorsports (currently non-adjustable, but they can be made single-adjustable for $700, and double-adjustable are being prototyped as we speak).
  • Custom bumpstops
  • Four different front swaybars (7/8" solid, 15/16" solid, 1 1/8" hollow, and the stock piece)
  • custom heim-jointed front swaybar endlinks
  • Four sets of wheels:
    • two sets of BBS (forged, lightest factory wheel at 10.5 lbs each) Two sets of centercaps and one wrench also included.
    • one set of SSR Type C (forged, hub face machined to be legal offset, 7.5lbs each)
    • 15x6.5 Enkei RS5 for the street
  • Two sets of tires
    • Hoosier Wets 195/55R14 on the BBS wheels (only used one event)
    • Dunlop Direzza DZ101 205/50-15 on the street wheels, 40% life left
  • Fully closed-box tire trailer, holds eight tires, has LED lighting and 12" wheels. Two spare hubs and one spare tire also included. Box on the trailer can be locked.
  • Hard Dog trailer hitch
  • Jackson Racing air filter
  • Borla stainless steel catback exhaust
  • Lots of spares
    • two spare front wheel hubs new in box
    • two rear wheel bearings new in box
    • ANR heavy-duty front sway bar mounts new in box
    • two sets of swaybar endlinks (Racing Beat and Mazdaspeed)
    • complete air conditioning and power steering systems (removed during package conversion)
    • real oil pressure gauge and sending unit new in box (original gauge in the car is actually just an on/off deal.)
    • K & N air filter with recharger kit
    • factory exhaust
    • Enthusiast’s shop manual and Haynes Manual included
Maintenance:
  • radiator replaced in 2007
  • timing belt, water pump, all cooling hoses replaced at 68k miles
  • heater core replaced in 2007
  • shifter boots replaced at 68k
  • clutch replaced at 83k
  • transmission and diff fluid are synthetic, done at 68k
  • all front suspension bushings, tie rod ends, and ball joints replaced at ~75k
  • brake rotors and pads replaced at 68k
  • brake fluid flushed and replaced in 2007
  • clutch fluid and slave cylinder replaced in 2005
  • spark plug wires replaced in June, Magnecor
  • fuel filter replaced in 2005
Asking price for everything is $8000.
Pics to come later, along with more info if I forgot anything.
Holy shit, never thought I’d see this car for sale!
GLWS Brett.
I guess this is what the company shutting down makes you do huh :frowning:
Actually, that has little to nothing to do with the sale.
G/L with the sale.
Bump for a guy I know when over this car bolt by bolt.
Got any plans for a replacement?
In for pics, sounds like an AutoX champ.
damn, VERY interested … except it’s likely more setup than I wanted to start with but that could be a money-saver in the end (I keep telling myself to buy someone ELSE’s project lol)
What are you doing next Brett?
x3 on what’s next - I know you’re not dropping out of the game… ironic that two big players are selling their cars at the same time. you co-driving the s2k or something? :slight_smile:
Damn, GLWS!
cant waut for the pics
Here’s a couple of pics. I’ll get some underhood shots up this weekend, along with shots of the trailer.
As for the replacement, it will be RWD. That much I’m sure of. I’ve got a few choices in mind, but I’ve got to save some money first before I can pull the trigger. Reason for selling the trailer is that none of the cars I’m considering have tires that will fit in it, and the one car that does have small enough wheels and tires can’t be driven on the street.
i still want an explanation!!! :slight_smile:
edit: good luck with the sale though
Some things I forgot:
Car has a five point cam-lock harness (using lap belt only right now due to SCCA rules)
  • full set of spare alignment bolts.
  • extra set of stock springs and stock bumpstops
I also have a Hard Dog Hardcore single-diagonal roll bar that I will sell separately for $300. It has SFI padding along with a fitted vinyl cover. This bar is legal for use at track days and time trials, etc.
This is a turnkey auto-x setup. Just add one or two sets of fresh tires and you are good to go. An ES Miata is probably the cheapest stock class car to run from a tire-budget standpoint, as the tires cost between $750-900 shipped, depending on whether you go with Hoosiers or Kumhos, or have them heat-cycled. You can get 100+ runs out of a set of V710s, and pretty close to that out a set of A6s if you flip them and rotate them properly.
^ I was going to ask if you still had that roll bar.
:tup:
glws man…can’t wait to see what’s next!
Holt shit man glws, havent seen you since the transit roller skating x-mod days lol
car have AC?
read the first post.
power steering and AC systems were removed but are included in the sale.
GLWS Brett. Hope you can find snky snky what you’re looking for!
-Anthony
in for pics
Mods can close this thread. I’m keeping the car for at least another year.
