hey. this is my dd to get to school and while my car at hybrid. i need this thing running again. its a 97 eclipse nt.  (420a)
well there are sparks, and fuel pump is pumping. and pressure is building up in the fuel rail. it wants to turn over but it dosent.
i put starter fluid in the TB and it started up and as long as the starter fluid was sprayed he car runs. but then when i stop spraying it, it then dies.
i think it may be clog injecters? any ideas
ok quick rundown on wha ti have already done:
starter (good)
change spark plug
check for sparks (good)
check if the fuel pump is working/ clean the filter with air (good)
check for pressure in the fuel rail (good)
what else im i missing? or amyb some want to check it out for me?
