I thought that 475 was supposed to spool around 3 and change? What i have been reading is swap the basket to a billet one and replace the clutch packs and some other small things in there and they hold good power.
ill have to do some more research between the two. 4l80e with a manual valve body and shift kit will hold better you say?
It will spool around ~3500RPM, but with that faggoty 2 speed you’ll need all the stall you can get. As for a 4L80e, you don’t need a FMVB. You are better off letting the transmission shift itself, I can even setup a switch that forces it into full manual mode when you want it to be that way.
Plenty of RX7’s, supras, gremlins, datsuns, (lil light cars) with v8 turbz running glides and doing just fine on the track. If the thing can get on and off a trailer its fine by me. realistically I dont see this thing hitting the streets under its own power. Dumping it off a trailer at midnight… thats a different story.
Well if you don’t plan on it hitting the streets, fuck it. Run the glide. Build it yourself if you can as they seem simple. Don’t skimp on the converter though…
its all a learning experience. parts are cheap for them and its just like legos, piece comes out and piece goes in. we will see what happens. At this point though, I can start putting the rest of the front end together, motor, radiator, turbo, exhaust, charge piping, IC, plumbing, fuel system, etc. then fill in the middle part later (trans, drive shaft, trans cross member floor, scatter shield, firewall)
