We just finished our portion of the diagnosis on an interesting issue.
The car is the Evo 8 we posted the 674 whp dyno from.
The issue is that below a certain temperature the car wouldn’t start on it’s CDI + COP ignition setup, but started fine on the stock ignition. Oddly, I could warm the car up on the stock ignition, then fire the car up on the COP ignition with the temperature just as cold outside.
After testing we found a few things.
At 45 F and the car at ambient temp. from not running for a while, the CDI + COP setup provided strong spark.
At about 42 F and the car at ambient temp. from not running for a while, the CDI + COP setup provided very weak spark.
Under 40 F and the car at ambient temp. from not running for a while, the CDI + COP setup provided no spark at all.
So we started scoping supply voltage at the CDI during cranking at various temperatures and found they were consistant so the battery was providing enough voltage even at 35 F.
Then we picked a day when it was cold enough that the CDI wasn’t firing and ran jumper cables to a running car to get excellent voltage to the Evo during the cranking test. Still no spark from the CDI.
So today it was just barely warm enough that the CDI did provide spark. We double bagged the CDI box and stuck it in the freezer for an hour, took it out and plugged it in, no spark and the LED on the box didn’t even light up at key on.
We warmed the CDI box up by itself to 70 F, leaving the rest of the car cold and the car has real strong spark.
I was definitely expecting this to be a voltage issue where the colder the car got the battery just didn’t have the CCA to get everything going, but it’s really a temperature issue. The box is going back to the manufacturer in Australia for inspection and testing. They feel an internal component may be damaged, making it affected more than usual by the cold. We shall see.
BTW…for a few days I was warming the car up on the stock ignition, then swapping to the CDI setup. Once the engine bay was warm it worked fine LOL.
