happens everytime my car gets close to completion!!
whats happening:
2 matching kunckles (obv one driver and other pass)
2 identical hubs
2 identical bearings
2 identical snaprings
i checked all lengths and everything!
went to press in first bearing and everything looked awesome
went to press in the second one, the piece of the hub the bearing sits on sticks out slightly farther than the bearing itself
so i put them next to eachother, bearings sit exactly the same at the same spot inside the knuckle, both snap rings are in properly, and both hubs are equally spaced out from the surface of the knuckle (entrance for hub after bearings been pressed in)
the hubs are the same length, and theyre at the same spot but somehow one is further passed the bearing than the other, im kinda losing my mind, pics to come
ideas for now: grind off the remaining 1/8th inch of the hub that sticks passed the bearing so the surfaces are even for the axle to sit on
2. maybe thats just the way it is and i never noticed cause driver side and pass side are obviously diff axles
