What do you do for a catch can??? post pics if possible.
Car is a S13 w/SR20
thanks,
Fitzy
Car is a S13 w/SR20
thanks,
Fitzy
if oil catch can than this
(sorry about unresized pic) and yea its a stock manifold
I’m running the Manifold that Bing sells which sorta gets in the way of the location for the stock Catch Can so I just removed it and I dont run one…
Was a pretty simple solution
Just install one on the other side of the breather tee.
and no problems???
i am running the same manifold ![]()
not running a catch can isnt the best idea, increasing your chance of getting a no catch can ticket and if your venting to your intake pipe it clogs up your turbo, if your not gonna run one at least make a hose that runs downhill to the side of your engine compartment so it can leak down on the ground, and make sure you put some mesh on the end so that sand and stuff doesnt fly up in there accidentally
and no problems???
i am running the same manifold :)[/quote]
No problems at all “its been almost 2yrs”
Of offence dude, but I would not speak about that of which you know nothing about. There is NO LAW stating you have to have a Catch Can. There is however a law stating you cannot have a Crankcase Vented to Atmo and you cannot have a Filter on the end cause its the same as Vented it to Atmo.
It could… IF you get or have that much blow by. And not every engine will be the same so some will get a bit of Oil and some wont. Mine for example seems to get barley any/none at all. A friends in town here however, gets alot.
If you search on the 240sxforums.com you will notice many of those guys either
#1, plug both holes
#2, plug the front hole and only have the rear feed to the block etc
#3, they dont run a Catch Can and just have it ran from VC - Block and VC - Intake
If you notice Oil building up inside your intake tube/turbo inlet then you need a Catch Can, if you dont get Oil build up then you dont need one.
By ‘no catchcan ticket’ I’m sure Vlad meant a ticket for an open breather.
good stuff guys, there must be more out there…
lol such a hater, i have installed my catch can so how can i know nothing about ? hahaha, what you just said contradicted yourself, no catch can = vented to atompshere OR vented to intake = clogged turbo, easy enough ? do you want me to write you an equation ? lol, or hey, why dont u put ur cock in there hahahah, peace, im not gonna waste another thread on arguing, these kind of people are who make up the worser part of the human society
thats nice kids, save it for PM’s.
i shelled out a few dollars and a greddy catch can is on the way along with universal T bracket. i’ll figure something out.
Fitzy
Vlad -Just thought I should tell you now, rather than have you find out in some weird way, but I had sex with your sister.
wicked.
