Ok, so new MAF didnt fix anything either. I wasnt sure it would, but I had to replace it since it was broken anyway. Here is waht I have done so far…
Two sunday’s ago I lose a complete electrode from CYL1 spark plug (like completely, right back to the resistor) and CYL1 code is set (duh). This happened while running WOT shifting between 4th and 5th. Car is not chipped, completely stock.
I can never find the missing electrode, my only guess is it somehow got thru the valves and out through the wastegate.
Compression on all cyls is still good, something like 193/196/200/200.
I bore scope all the cyls I cant find any damage or remnants of the missing electrode. Also looked at the turbine blades through the O2 sensor hole, no damage there or sign of the electrode there or on top of the cat.
Put 4 new plugs in it runs for a few sec then starts knocking real bad, running rough etc.
I pull all of the coils off and check all of the electrical connections, and then spark while cranking the motor over. I have spark on all 4. Everything thing seems to test ok so far.
So I say F it put it all back together, get it started…sorta. After a few mins it starts to idle ok again and the knock goes away. Go for a drive, no misfires. I drove it every which way I could. Different loads, different gears, rpms etc etc. No misfires. I should note at this time that I had drained the oil to see if it was full of glitter and I only had straight 30wt to put back in ( ya I know I should have went to the store to get the right oil). There was no glitter.
This lasts 3 days until once again I am driving it and it starts to misfire.
I limp it home and its back to its old crap again. Misfires ahoy etc and now its knocking… sorta bad.
I order 4 new coil packs and a new ignition module and 4 new Bosch plugs (the parts store didnt have the right ones). I also get the right 0W40 oil and a new filter.
Get those all in. Car fires right up and idles no issues, except the knock. I let the car warm up and go for a like 4mi drive. I get back to the house, the knock is gone. Must have been a lifter issue. I take it back out and get a misfire. Clear it. Drive about 5 more mins, get two more misfires. ugh.
I pull the MAF out to clean it, since Im running out of ideas. As Im cleaning it with a Q tip and some alcohol a little piece of the filament fn falls off… ya, broken. UGH. I just hardly touched it… I used to clean other MAFs all the time, never had this issue.
So I take the car back out with the MAF unplugged, running in limp mode. Drive it around like this for a while, no misfires. So maybee it was the MAF all along.
Pick up a new MAF from the dealer , get it in. Its no better. Still misfiring etc. The knock is still gone, luckily. Its like nothing has changed.
Im running out of ideas. I havent checked the fuel pressure yet. Otherwise any thoughts on what to do/check next??
Also, what besides MAF and O2 does the car ignore in limp mode? Im guessing if I go back out tonight with the MAF unplugged it wont misfire anymore.
THoughts?
Thanks!
Dan
