hey guys… freshly swapped like a month ago from my old s13…
so ive been toying around here and there making custom things and i finally was finished last night…
turned the key, walboro turns on… that was a good sign,cluster turns,lights signal high beam…everything is fine…
so i turn the key and i just hear “click” from the right hand fuse box
wellllll…that kinda puzzled me because the fuse box on the right side has nothing to do with the motor turning over…
so wut do u guys think… there was sumone on here with almost the same problem, but he didint connect some wires… i have checked over the lower and upper harness and i dont seem to see nething out of place.
i unno thats y im posting… could be the starter… but it doesint even crank nothing,just CLICK when i turn the key and power loss to my radio until i let go of the key ( which was only a second neways )
get a multi meter and place it onto the starter terminal, turn the key and see if its getting power there at the same time…
if you are, then ure starters gone, if ure not, then check the main fuse and relays.
I had the same problem, exact same symptoms, did you relocate your battery to the back? As someone suggested, try checking the voltage at the starter. My issue turned out to be not enough juice coming from the battery, had to run a new cable from the battery to the front.
Had it happen once, just pulled the starter. Tested, pulled an old one from junk and shoved that one in. Mine had clicks so i asumed it was fried or shorted or something.
