I had a brake line rupture due to rust on my work truck. Thankfully this happened in my driveway and not on the highway. Apparently this is not an uncommon occurrence for early 2000’s GM trucks and I should consider myself lucky to have only had to have dealt with it at this point.
I was hoping to get this job done with minimal effort, but of course the line ruptured above the gas tank and below the bed. No easy repair option to be had I decided I’d just replace most of the lines and upgrade to stainless.
I purchased a pre bent kit and got the bed removed. Most of the removal and install went quickly but when it came time to bleed the system a leak developed where the new lines connect to the brake pressure modulator valve.
I loosened and retightened the nuts several times without any success. I believe all of the flares are in good shape and have no reason to suspect the mating surfaces on the bpmv are fouled. I’m wondering if the hardness of the stainless steel is stopping the flare from forming to the seat?
if this is the case I have heard of using a soft copper washer to allow for this deformation between mating surfaces to happen. Has anyone used this method to deal with a tricky brake line connection? Did it work? Where did you find the washers?
any advice would be appreciated.
