built ka-t hard time starting!!
Have been having an issue turning the KA-T on after it has warmed up, before it wouldnt even turn on after it was warm but now after I changed the distributor today due to a sensor in the old one not working properly,it kinda fixed that issue but not really.
right now what happens is when I turn the car on when cold it comes on right away but after driving it for a bit and turning it off the only way to turn it back on is to pull the fuel pump fuse, crank it till it starts and uses all the fuel then put the fuse back in and start it.
Also I stalled the car(yay to rb20 flywheel 350z nismo unsprung clutch )on kinda of a angled street(angled so the water goes in the gutter area)and when I tried to start it all i got was white smoke!! I was soo scared that I blew the head gasket but after I did the whole pull the fuel pump fuse and put it back in thing it started up.
the only things I can think of being an issue right now are the following:
- leaky injectors(probably not since they were in my other ka-t and I just removed the rail and put it in this one)
2.blown fpr(dont know the Symptoms)
- leaky headgasket(if this was the case wouldnt I have white smoke all the time?)
the setup btw is:
ross 8.5:1 pistons
eagle rods
cometic headgasket
rebuilt head
650cc injectors
n60 maf
tuned ecu w/ safc2(tune is for 550’s using the safc for taking away 15% fuel so its not rich)
any help you guys can give me would be awesome .
I dont take any offense to sr guys
they like their gutless motors and I like my brass balls motor :). we have different tastes thats all :p.
