Can someone help me with this
I turn the key to the on position and hear the fuel pump. I turn the key to start and rather than hearing the starter I hear the fuel pump pump more at me. I was completely confused and messed around with stuff such as my tune/ostrich/chip and dizzy and starter…I think this issue was the distributor connection so I rewired it and fixed it all up.
When I completed this I plugged the battery back in to find my car power on instantly… Turbo timer was ON, fan is on, check engine light, gauges, oil light, battery light, fuel pump, everything.
I started unplugging: Dizzy no effect. main relay stopped the fuel pump/injectors. I then noticed electrical tape on an injector wire melted and pulled them. I pulled the ECU with no effect.
Anyone have any advice? Which wires should I be looking for?
