Also if you are running a low profile tire, they tend to track to the road, so highways and such that are slightly banked for draining will cause the car to slighty track.
One of your brakes could be hanging up just a little bit… this would also cause the car to wander… If it’s pulling to the right, its gonna be a right side caliper that is hanging up on you…
I’ve been told that off-caster can cause a pull to one side as well… but with my suspension knowledge this makes no sense to me if your going in a straight line…
Start with tire pressure… then check to see if yur brakes are hanging up… this you can check by taking a casual stroll around the neighborhood… come home, and put yur hand near the rotors… if one is a whole lot hotter then the rest, thats yur culpurit.
Might as well check your camber kits in the front too (if you have them), they wear out as well. Mine were shot to shit when I took them off, and they probably have some effect on how the car tracks since if they are unable to hold their settings (bushings fail) then your alignment never stays the same. Every bump will slightly change it
^^Also a very good point. :tup: But, the little noise you hear is most likeley a worn control arm bushing. Have yours been replaced? if not check them, and do a shake test on the wheel to make sure your bearings and tie rods are nice and tight. Genrally with the tire in the air, grab it and shake it left to right to check steering parts, and up and down for the bearing. There should be almost no movment if everything is in good shape.
