Clutch Bleeding **ASAP will pay**
Need some help bleeding a clutch in one of my s13’s, its damn near impossible because that box under the car where the lines go in and where the valve goes keeps trapping air.
If anyone is well experienced with this, I will pay for your time.
Located in Mississauga
Bend the lines carefully and bypass the box, then you can bleed it more easily.
:werd: you should definitely eliminate the clutch dampener… it’s useless.
then just bleed it from the slave cylinder.
As if that’s going to help him doing it alone. :hsugh:
Clutch bleeding is still a 2-man job (unless they have those one-man-bleeders) :dunno:
where abouts in sauga are u.
i could drop by if u still need a hand
pm me / shift_krunk@hotmail.com (msn)
I added you to msn
anyone around the Oakville area this evening, I also need to Bleed my clutch and It seems now it is more of a pain in the ass then I thought.
please let me know asap,
