i cant get my buddys clutch to bleed its a 93 hatch sr. ive bleed alot of clutches but this is stupid something is wack.any imput
does it still have the clutch dampener installed? I’ve always had luck with a gravity bleed followed by pushing pedal down when bleeder is closed, open bleeder. close bleeder. pull pedal up by hand and repeat
thats been done many times i even have a vaccum bleeder no such luck. its like the slave isnt engaging soon enough… like the fork is to far back or something but its all assembled properly
delete the dampener or prepare to pump for hours.
This Guy, his name was Dylan, figured it out <3
Your welcome noobzzz
starts a theatrical slow clap
ps you comin to the shop? im bout to head there
close the bleeder and reservoir .pump pedal , remove reservoir cap and watch for fine bubbles .if you do see bubbles,close cap and pump again and you end up pushing air out from your reservoir and thus bleedind it. sometimes the bleeder doesn’t work.
its all figured out haha
adjustable clutch pedal! fuck yeah!
good, you figure out the problem. cars remain and will always be a pain in the ass
