I am having a problem with the clutch in my 98 accord. The clutch is grabbing right off the floor all of the sudden, and it does not want to disengage fully sometimes. When I pump it, it will build pressure again. Is there a way to see if its the slave or master cylinder for the clutch?
One should be leaking. :dunno:
-j
Hmmm…just checked the slave, doesn’t appear to be leaking. I’ll have to check the master tomorrow. Master is only $54 at pepboys
the resovior seems to be full still
Clogged line maybe?
Curiously, are these pics a pretty good representation of what you’re dealing with?
exactly almost…the slave is front and center to change, i just will need help bleeding it afterwards.
