THE STORY
So here’s the deal. I’ll recap from the beginning.
After a drift track event where on mulitple occasions
I did clutch-kicks.
I maybe did 5-7 cluck kicks at the event…all within
maybe 5-10min apart
After the event on drive home, I was climbinb a hill
and I would floor the gas and the revs just shot up but
car didnt move
After a few more weeks of driving, it was evident my
clutch was slipping I assumed it was the clutch.
THE WEIRD PROBLEM
But then last week I went to take the car out (it hadnt
been driven for more then a week) and I went to reverse
and the car just lunged back. I put it in 1st and
sure enough it lunged forward. At which point I figure it
might be something along the clutch lines, so I figure I
bleed it.
Well another week goes by. It’s now today, and I decide
to bleed the clutch. I only did the master for now.
TIME TO BLEED IT - STILL WEIRD PROBLEMS
Basically I topped the resevoir off, had my dad pump the
clutch a few times, hold it on the 5th or 7th pump, and
when I unscrewed the valve fluid would come out.
Close the vlave after a few seconds, and then re-did the
procedure all over again.
I was told not to fully take the valve screw out but even
when I unscrewed it a bit, fluid would come out the
opening and not through the top of the valve.
As well, i would notice the pedal arm near the cylinder
slowly moving back in as the valve screw was open.
DRIVING
Well, anywho finally took the car out for a spin.
It seemed to drive fine.
The clutch was grabbing. Maybe a little earlier then usual
but it was grabbing and holding on
However, a few times that I stopped fully at a stop sign,
and then started to go again in 1st, as I was releaseing
the clutch, the car bucked (at which point I would push
clutch again and put it neutral) I would put it in 1st
again and then it would drive off normally.
As well, a couple times that I tried to downshift from
3rd to 2nd or 4th to 3rd or whatever, the pedal got stuck
a couple times.
In anycase, the car seems to be driving except for
those two problems: bucking, and pedal getting stuck.
Help!
