Last winter I had few cases of my car shutting of as I pull out on cold days.
Today I had the same thing happen to me, I start the car let it idle for 5-10 minutes and as I turn my wheel all the way to the right I hear belt squeaking noise and my car shuts off.
isn’t there a BMW forum you can go and shit up with all your questions? i bet they would have more useful input rather than us ragging on you every time
id say something wrong with the rack/pinion and or power steering pump. somethings making the pump stall out your engine. have you checked the fluid level?
How bad is the fluid leak? Did it start leaking recently or was it leaking last year when it did this too? Do you add fluid to compensate for the leak?
My e30 used to have a power steering leak and I had a similar issue until I fixed the leak. In my case if the car had sat for a few hours I’d have difficulty steering at first and the rpms would drop significantly while moving the steering wheel. After moving the steering wheel back and forth once each way it would operate normally again.
