Rig -
i7 920
XFX X58i MOBO
6gb 1600mhz OCZ RAM
1220W Kingwin PSU
(2) 1TB HDDs in RAID 0
GTX 260 216 SC (my GTX 295 ships on the 2nd)
Logitech G15 keyboard
MS V5000 wireless mouse
Vista x64, fresh install.
All of the recent drivers (that I can think of)
First problem -
From a Shut-Down until my cursor is ready to open applications is almost exactly 2 minutes. My P4 machine booted up in less than a minute. I tried changing the msconfig boot setting to utilize the 4 core than the 6gb memory on boot, but so no difference at all.
When I start the stopwatch -
12 seconds in my XFX MOBO screen flashes for 2 seconds.
Black
From 32 until 43 seconds in I get the Welcome to Windows bar
From 1:18 until 1:21 I get the Windows orb
No login prompt (no password on account) and then after 2 minutes it is done loading the desktop.
When I put it to sleep:
Takes 42 seconds to finish loading the desktop.
Second Problem -
My keyboard is plugged into the MOBO for USB 2.0. My mouse is plugged into my keyboard. They take forever to “turn on”.
Once everything is up and running, it flys… just takes a couple minutes to get there.
My MOBO has RAID SATA ports, which I believe are being used correctly, and the fact that I have (2) 1 TB drives and I’m showing 1 TB of total space, and showing 2 drives (channel 0 and channel 1) I think the RAID is functioning.
I don’t know if it is setup correctly for sure though as this is my first RAID application.
I should have been more clear. With the G15 it has a built in LCD with an interface, right on the keyboard, these functions are “off” and the backlighting on the board is “off” until about 1:30 into a boot.
I can understand that if I was in windows… while it was loading the drivers, but it takes so long to even get that far. People on lesser computers are getting in from a dead PC in about 30-32 seconds.
That seems like a valid approach.
I did that for a no-post problem. The quick reference guide for the MOBO said to use 2,4,6 for 3 dimms in triple channel. Turns out it is supposed to be 1,3,5. That didn’t take too long… but what a pita.
