When on the brakes the front end gets the shakes.
Its enough to get the wheel to bobble some.
I figure the rotors could be warped, but there is no feedback in the brake pedal. With constant pressure, the pedal never budges.
I replaced pads/rotors last fall because they were worn down and it felt like they had been a little warped. They may have never gone away since I told the wife to take it easy on them for a while.
I’ll probably buy a dial gauge and measure them, but what else might cause it? Tire out of balance?
It’s pretty annoying and I’m sure I will fix it eventually. I’m just lazy.
Am I the only one who’s had good luck putting the cheapest rotors they can find on their DD? Seriously, I’ve never spent more than $10-15 on a rotor and have never had problems.
Nope, I once wasted $200 on a set of “Top-of-the-line” rotors for the Grand Am. They turned out to be a waste of money. I went to Napa and got their 13 dollar rotors. Never had a problem after that.
I used 22 dollar rotors up front on the F-150 that lasted 3 years (20K) before I gave up the truck.
Maybe its because you drive a 5spd. and once stoped sit in neutral as opposed to
keeping the pressure on the pedal to hold your car in traffic?
[/quote]
Eh you shouldn’t have to do that.
If it were me, I’d take just toss new disks on and only replace the pads if they’re worn out or unevenly. Clean and lube the sliders while you’re in there. Granted it’s a high performance redline :burnout: but it’s just the woman’s DD.
