I know I installed a bunch of your guys houses recently. I know most of you don’t have a home phone line so your paying the additional charge on your dual tuners.
The ethernet port on the 622/722 receivers are alive and working now. If you plug it into a modem or router you can then go to menu, 6, 1, 9, 1 and you should have a connection to the net (IP address, ect.). That receiver can then use the net instead of a phone line for PPV ordering and it should also knock off the charge. Only one receiver needs to be connected this way if you have more then one.
But yeah, only one needs to be connected. Right now all its doing is PPV and taking care of the phone line charge(s). I’m sure they’ll have more uses for it, but thats it for now.
Right now I still have mine hooked up and working through my vonage phone line so I guess I’ll leave it be, but nice to know should I ever want to drop the home phone.
I’m hoping DVR programming via the internet is in the works.
They started pushing down the software to allow you to download movies via the broadband connection. I don’t have it yet but I read that it will work for the 622 and 722 receivers. Looks like Dish’s answer to on demand.
[/quote]
You beat me to it! I just found out about that today as well!
Yessir. though i think i bricked it whilst rerouting / connecting wires. only showing 110 & 119 on switch test, yet straight connection shows all three.
:poke:
[/quote]
I know why too. You have the wing dish (61.5) piggy backing off the DPP Twin, which is the way to do it without a switch.
You add the DP44 to the fray and you need to run another line from the 61.5 dish down to the switch (input 3). Otherwise, it won’t find 61.5.
CNN, USA and SCI-FI were weeks ago. 4/18 for USA/SciFi and 4/16 for CNN to be exact. You dish employees guys are so out of the loop.
And while I won’t ever be upset about more HD, why exactly do I need CNN in HD again, especially when 90% of there stuff just has black bars on both sides of the screen?
But :tup: to getting the 2nd season of Burn Notice in HD.
