Squeaky clutch problem usually can be fixed by use of a little lubrication, ensure that all the bearings and bushings are properly lubricated, there might even be trouble with transmission input shaft bearing. And if your vehicle squeaks while on neutral problem might be due to faulty pivot ball contact. So basically the problem does not seem to be that of an issue and is probably related to some rustic parts and low on lubrication.
