i’m running 11.6" rotors off of a newer SHO but I have tossed the stock calapers in favor of the much stronger cobra calapers which I have modified to fit 11.6" rotors instead of 13" rotors that they were origionaly designed for.
problem #1 with hawk HP+ pads they fade due to pad hear very fast + blue rotor on the street. The don’t fade durring autoX but they do blue rotors so they are close to fading with these pads.
problem #2 The last autoX my car was at I cracked a rotor, I don’t mean the little stress cracks I mean a 1/8" crack that was about 3" long
solution #1 upgrade to track pads to solve fading brake situation.
solution #2 don’t run china rotors?
solution #3 go back to mushy stock calapers and track pads. the stock calaper sweeps the entire rotor where the cobra only sweeps the outer 2"
or so. overall braking performance comparing the stock ford pads on stock calaper on 11.6 stops faster and lasts longer compared to the cobra calaper with HP+ pads. The rotors hold up a lot better to the stock calapers due to the full sweep rather than having more clamping on the outer edge.
solution #4 get track pads for cobra calapers and bolt 13" rotors on car upon arrival at track. If i cord a slick while i’m there this would require me to swap hot brakes to the smaller size.
