Curious to what things you guys have done to fix wheel hop. I went to the track last night and when launching hard i would get wicked nasty wheel hop.
I got coilovers, TC rods, UC arms and r comp tires. Could worn subframe bushings be the cause of my problems. Or is the key in the suspension stiffness and tire pressure as i didn’t really bother changing anything for drag.
I ran a 13.6 @113mph and a nasty 2.5 sixty foot. And some how i broke my turbo elbow again
Yeah im not surprised wheel hop did that to my elbow then… It was not pleasant by any means. Sounds like i need to spend some time setting up the car next time before i go. Thanks for the tips
Hey steve… why don’t you try swapping in an s14 subframe. The different geometry reduces anti-squat, and plants the rear end with less toe/camber while under compression.
Lots of places sell offset solid bushings for them too (the front subframe holes are 1/2" off on an s14 vs. s13)… you can make the s14 fit, but its a hard squeeze without a lift.
