So I have to put a new fuel pump in. Here’s my potential problem.
I have steel braided fuel lines. Initally when I installed them the were clean of course so it was easy to heat the ends to help them slide over the barbs on the fuel pump. Now I have to put them back on the new pump but obviously heating them is not an option.
Is there any kind of lubricant that I can put on the barbs that will help me slide on these lines a little easier? They are only plastic barbs on the pump. But they have a small ridge that you have to get the line over so you can calmpit on the other side.
Can you use some kind of lubricant there that won’t hurt anything or contaminate the line? I wouldn’t need very much I’m sure.
Curious? Anyone?
Hope it works
