I just picked up a HP Pavilion DV250 and have a USB720 VZW modem. I downloaded all drivers and program correctly, program opens,when USB is plug in it powers up correctly, hit connect and it says access denied. I called verizon they said everything is fine on their end, they said it might be the firewall not allowing it to connect. We even went through an activation to make sure the USB drive works correctly.
maybe the modem itself?
did the right information go into the modem? (is that how they work?)
id call verizon and just chew their ear off and see where that gets you.
We put the card in and went to sign on, it connected for like 5 minutes and came up with an error 25, went to sign on again and it said access denied error 5…
everything worked correct … with the VZAccess all drivers installed correct (well you would think they did )
when you set it up we did everthing correct … the usb powers up correct … the phone # shows up on the VZAccess and you hit connect and it says “access denied” but nothing else like not :your out of network" or anything crazy so the VZW guy thought it was a firewall block from vista but there is nothing on unless there is something going on that i dont know
good thing is its a new laptop so i can just wipe it all out and start new . im going to go to a VZW store and ask for a real VZaccess disk
OR if anyone know where online to DL the full program I think this is where the problem is
I will love vista if we can get the internet to work…
Also I will add our best friend bought the same laptop at the same time she put her aircard in and installed the same program we did and hers works just fine ( we did nothing diff then what she did)
well so far it was something wrong with the program … we DL the new one and it installed correct … last time i had to move the drivers over by hand … ( this could have been the problem)
