Head Gasket replacement
I need to replace the head gasket on my boat, what Im wondering is if there is a need to use any type of sealer or anything like that on the gasket??
or do i just leave it as is??
thank Jerry
Not that I would have the answer but you might want to add more detail on the motor and such.
[quote=“SVT3945"”]
thank Jerry
[/quote]
HOLY CRAP! You are alive!! :headbang:
generally no…the gasket is the sealing component…but some like to add a bit of RTV to keep it in place
Do not put RTV on a head gasket
brain fart…I was thinking valve cover gasket on the RTV part
[quote=“JUICEDSS,post:3,topic:26177"”]
[/quote]
Thats what I came in here to say :headbang:
is it a 350 merc cruiser?
some people will use copper spray and spray a couple light coats on the gasket. I have used it only once when assembling a block/head because the block I was using had the most chewed up cylinders I have ever seen on the top of the shortblock. I honestly didn’t think this motor would hold compression at all and only had 1 day before auto-x started. Low and behold it’s still holding strong (although I wasn’t expecting it to do so). In general I try to stay away from the copper spray because its messy as hell come rebuild time when you gotta get all the old shit off.
[/quote]
HAHAAHA i thought the same thing :wiggle:
Im still alive you basturds !!!
someone find me a replacement head for my boat that cost less then $800
