last night after the firewerks am on the way home and some asshole stops on a green light and i hit em on the back. my car is really low so it only damage my hood a lil my lights and everything else is ok, but the engine wont start.
it was late at night so couldnt check fuses or anything, but when i turn key starter moves but am not sure whats keeping car from going on>?
o word, i had no idea about nertia cutoff switch i got honda 92 accord, the hood just crushed back a lil but nothing was hit, no radiator fluid or anything lights ok. i got electric power but it may it did sound like engine was not getting fuel or turning over. what else can i look for?
The car stopped running right after the accident, right? on my focus the switch is in the passenger footwell, marked by a gas pump with a line through it. Try searching around on some forums…
Search around for the cut off switch under the dash on the Pass side maybe. You might have to pull back the carpet some. Not sure if Acks have the switch or not.
i think thats a ford only thing i have never seen it on anything else. however try checking all the fuses under the hood and in the pass. compartment. you may have a blown fuse that will not allow something to function.
yeah, I cracked up my 96 civic and it started right up afterwords, so I don’t think an older honda would have one either.
Cranking or turning over = the chugging sound of the engine trying to start. Not cranking, all you will hear is the click of the starter, or nothing if the starter is bad.
no, battery runs good everything on the car works i mean everything. when i turn key the starter it moves and you here it spin and if you leave it long enough you get that high pitch sound the starter makes.
