there should be clips that you can bend to take it out… just push on it from the inside, out
i found this one http://www.newegg.com/Product/ShowImage.aspx?CurImage=13-135-220-04.jpg&Image=13-135-220-02.jpg%2C13-135-220-03.jpg%2C13-135-220-04.jpg%2C13-135-220-05.jpg%2C13-135-220-06.jpg&S7ImageFlag=0&WaterMark=1&Item=N82E16813135220&Depa=1&Description=ECS+KN1+SLI+Lite+(1.0A)+ATX+AMD+Motherboard
but i does not look like it would even come close to fitting cause the I/O panel is on the wrong side
opinions on this board?
i think im just going to buy a new case and stop trying to get it to fit the one i have
edit:
or there is this one i found
Get a new case without a PSU since you just bought one.
find a mobo with one IDE cable for your Hard drive.
Get new cd/rw drives
All in all it will be like 300.
Case is like 50, drives are 40, new mobo is about 150. make sure your ram and cpu will fit, and the voltages are correct for everyting.
or have baldy do it for you
