I did ipconfig/release and ipconfig/renew to establish an ip
Pings are succesful with 50% data loss and IP DNS and all that is now showing an actual ip and such.
It still will not connect to the internet, through ethernet or wireless
I go to IE it will say its detecting proxy settings web site found, waiting for reply, and the progress bar will get to about 50% before it gives up after 3 minutes.
I wish i could get it back to where it was, the wireless was working fine, and I sohuld have just left it alone, but i had to make sure the lan worked and then it all broke
In device manager, right click on your wireless with the ! and remove it. Then right click on the top icon and scan for new hardware. Should work to restart your fux0red driver. Enable/disable doesn’t reload the driver. Don’t worry, the driver is still on your computer so you won’t lose it when you remove the device.
I uninstalled the device and searched and reinstaled it, entered the wep and told it to connect, after about 20 seconds it appeared to have connected but sitll had a red X on the device. No packets were transferring and pings were unsuccessful
It still has an explamation point next to it in device mangler.
I feel like this is so close to being done but something stupid is in the way.
