Help with internet issues
Do you have any other devices hooked up to the router?
This is sweet
and the one person I was hoping/expecting to chime in does…and doesn’t provide anything useful.
it’s like the blind leading the blind
yes, 2 computers connected via cat5 and one connected wirelessly. its a linksys router
If you’ve still got a problem in device manager don’t bother fucking with connection settings. You have to get the driver working properly first. Remove all of your network devices from device manager (both wireless and lan) then refresh or reboot. They may have microsofted and are conflicting.
that is wrong
both check boxes should be set to automatic
have you reset the router?
removed and rebooting
router is working fine with other computers currently attached. and has not been rebooted
edit: after rebooting, scan for new hardware, it picks up both adapters, and the wireless card shows, in the popup, an error as occured during installation and the device may not work properly, and the explamation point is still there.
Why don’t you work on one issue at a time…
Set Ethernet interface to automatically get IP/DNS servers…
Plug in Cat5 wait 30-40sec for it to get a address from the DHCP server/router
do ipconfig /all and paste into this thread
do ping google.com and paste into this thread
do tracert google.com and paste into this thread
Windows IP Configuration…
Host Name…user-b12d0412fa
Primary DNS Suffix…
Node Type…Broadcast
IP Routing Enabled…NO
WINS proxy enabled…NO
Ehternet adapter local area connection 5:
connection-specific DNS suffix:
Description. Intel<R> PRO/100 VE Network Connection
Phyiscal Address 00-D0-59-B8-6B-6F
DHCP Enabled. YES
Autoconfiguration enabled YES
IP Adress 0.0.0.0
Subnet Mask. 0.0.0.0
Default Gateway …
DHCP server 0.0.0.0
Ping request could not find host www.google.com please check the name and try again
tracert www.google.com unable to resolve target system name www.google.com
I had to type them since im doing nyspeed on a different computer.
ugh andy quit being such a work fggt
TFC tonight?
I thought you said you were getting 50% packet loss…You wouldn’t be getting anything with no IP :lol:
Does your NIC card have a link light?
i WAS getting 50% packet loss, before, now it wont do anything.
and It does have a light that shows a green connection and a flickering yellow telling me its doing something
after doing an ipconfig/renew
I got
An error occured while renewing interface local area connection 5 : unable to contact your DHCP server. Request has timed out.
Can you do an ipconfig /all on another computer connected to the same router…
Microsoft Windows XP [Version 5.1.2600]
© Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\StereoShop>ipconfig/all
    Host Name . . . . . . . . . . . . : webreglaptop
    Primary Dns Suffix  . . . . . . . :
    Node Type . . . . . . . . . . . . : Unknown
    IP Routing Enabled. . . . . . . . : No
    WINS Proxy Enabled. . . . . . . . : No
    DNS Suffix Search List. . . . . . : mygateway.net
Ethernet adapter Local Area Connection:
    Connection-specific DNS Suffix  . : mygateway.net
    Description . . . . . . . . . . . : Intel(R) PRO/100 VE Network Connecti
on
Physical Address. . . . . . . . . : 00-09-6B-42-28-CB
Dhcp Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IP Address. . . . . . . . . . . . : 192.168.1.101
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DNS Servers . . . . . . . . . . . : 192.168.0.1
Lease Obtained. . . . . . . . . . : Wednesday, March 04, 2009 3:25:41 PM
    Lease Expires . . . . . . . . . . : Thursday, March 05, 2009 3:25:41 PM
Thats because it is lacking the proper device driver needed for it to work.
Does the ethernet adapter have an exclamation point as well, or does that show the adapter as installed properly?
ethernet shows as being installed properly.
So this thread is confusing me trying to read everything.
Where are you at right now?
Plug cat5 direct from PC to router and you are still getting 0.0.0.0 IP?
Do you have a second ehternet card available?
