Right now, im at a cat5 from pc to router and the ip is at 0.0.0.0 and wont renew
Its a laptop and no i dont
You are set with obtain IP automatically correct?
As Justin mentioned, are you getting link? How about a light on the router indicating that port is filled.
everything is set to automatically obtain.
The light shows as filled as well as a blinking yellow im assuming is showing packets being transferred
dude, just because other computers on the router are working, doesn’t mean it won’t need to be reset. If the DHCP server in the router has gone south, the computers that have already received IP leases will still work.
JUST RESET THE FUCKING THING REAL QUICK
hold the little button down for 30 seconds, unplug the power cable, then reboot your computer
Connection-specific DNS Suffix . : mygateway.net
Description . . . . . . . . . . . : Intel® PRO/100 VE Network Connecti
on
Physical Address. . . . . . . . . : 00-09-6B-42-28-CB
Dhcp Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IP Address. . . . . . . . . . . . : 192.168.1.101
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DNS Servers . . . . . . . . . . . : 192.168.0.1
You have two networks on one router?
wireless and wired, is the only thing i can think of.
they should be the same
how many routers do you have hooked up?
looks like you may have a rouge
+1 on router reboot…
I would also be interested to see the output of arp -a on the current working machine
+1
Should be the same network
reset router and ip address appeared in cmd
ipconfig shows
Ethernet adapter local area connection 5
Connection specific DNS Suffice: mygateway.net
IP Address. 192.168.1.103
Subnet mask. 225.255.255.0
Default Gateway… 192.168.1.1
Can you change the DNS server to 192.168.1.1? Although if you’re not getting an IP the DHCP server might be incorrect.
one router and one cable modem
Edit: Billys how would i got about doing that?
uh let me look…I don’t quite remember on XP as I’m on Vista…I’m not sure if that’s it.
i appreciate all the help thusfar but after resetting the router and cable modem, im still stuck. which blows
Ips are established, IE still does not complete getting to a website
Pings are functional with only a 25% loss of packets.
Tracing route to www.l.google.com[64.233.169.147]
1 <1ms * * 192.168.1.1
2 * 10ms * 67.246.224.1
3 * 11ms 6ms gig3-3.rochnywbs-rtr01-nyroc.rr.com[24.93.0.189]
4 8ms * 8ms srp5-0.rochnymth-rtr03.nyroc.rr.com[24.93.3.161]
5 * * * Request Timed Out.
6 * 29ms * ae-3-0-cr0.chi10.tbone.rr.com [66.109.6.72]
7 28ms 29ms 28ms ae-0-0-pr0.chi10.tbone.rr.com [66.109.6.153]
8 * 29ms * 216.239.46.246
9 * 30ms 28ms * 216.239.46.246
10 43ms 47ms * 216.239.45.225
11. 48ms 47ms * 72.14.236.200
12 * * * request timed out
13 50ms * * yo-in-f147.google.com[64.233.169.147]
14 * 41ms 48ms yo-in-f147.google.com [64.233.169.147]
So you have a valid IP now… and can’t browse.
How about browsing by IP?
Yea, and the internet controller on the taskbar shows its connected, but with little to no connectivity.
Its like its there, but barely.
Ipconfig /all
Can you ping your gateway?
Can you ping your dns servers?
Browse to 66.102.1.99?
Can you ping 66.102.1.99?
