I’m sure a lot of you think the track would simply be too expensive, but really its not bad and I’ll tell you what this is one of those things where you cant hate on it unitl you try it. Driving at the track is by far one of the best experiances you and your car will ever have together. Having sex in your car with a top notch slutty is about the only thing that even comes close. That and cruising with about 15+ other pimp cars blowing off at hot slutties on teh sidewalk.
Ok so for you guys that want to price it out that haven’t bene I thought i’d help out:
Drift:
To actually be allowed to drive your car on track you need to have - 65$
A spare set of tires to drift on can be had at a junkyard with some work, mounting them will be about - 30$, you may not need a spare set of tires depending on how hardcore you are, however its always a good idea to bring a spare.
Fuel at the track itself will be about 15L for an entire day if you’re drifting, you really dont use that much fuel. so 15$ for fuel say.
Fuel getting there and back can be done within 35L if you dont push the car, thats another 35$
A drift day will cost you 145$
Grip:
As long as your car is prepped (i.e. good pads and tires) you wont have any problems. Don’t bother pushing the car hard if you have stock brakes as you’ll destroy your rotors and pads.
To actually use the track again 65$
Fuel at the track depending on how much you drive will be about 30L 30$
Fuel there and back is another 35$
If you want to grip you’re gonna be looking at about 130$
All in all its less than 150$ to have a killer time at the track, its so worth it even if your car isn’t fully ready, appreciating each mod as you do it can be seen MOST obviously at track.
Things like new brake pads will NOT be appreciated on teh street, but when you go to track good pads are key, without them the car will almost be a joke. Same thing goes for clutch type diff, and coilovers.
Finally if you’re doing grip, take down some times. See how much you can improve in a day, and then throughout the year. If you hit up nelson again you can see how your mods improve, and how your overal driving ability improves.
Most of all you gotta be silly and have a great fuckign time, like jover said leave the egos and attitudes at home, i’ll bitch slap the fool that acts liek a big man.
