Hey guys & gals, How you been? Well, when i got my car there was some problems such as steering rack needed work, windshield had a crack, e-brake cables snapped, and lastly Cluster did not light nor did the heads up display. Now after about 2 days i finally got my cluster out and took it apart. After doing so i tried a method which i have seen on nicoclub.com, but no luck. Now since im 15, and can’t drive yet i sat back in my chair and listen to some music, and had the heat on highest level. After that i took my HUD module and touched the thing where the key goes in. Now this is where it gets tricky.Every time it sparks when i touch the key thing the HUD goes on, but not the thing built into the cluster also once it is fully grounded on to the keything it doesnt light at all. Only when it sparks it does. My dad stated its a short somewhere. Can anyone help me. Also the cluster lights dont work as well.
Forgot to mention as i sat there longer and tried the thing over and over again the actual module which would be connected to the cluster began to light as it sparked.
Any help is appreciated
