Intense Motorsports Swap Details and Pricing
S13 SR20
Engine Set $2000.00
Includes Engine, Transmission, ECU, Un-Cut Engine Wiring Harness Mass Air Flow Sensor and Ignitor
Engine Install Labour $1000.00
Wiring S13 Engine Into S14 Chassis $350.00
Wiring S13 Engine Into S13 Chassis $150.00
Custom Front Mount Intercooler Installed $1275.00
Set-up Includes:
22x9x3 Front Mount Intercooler
Custom 2 ½” Mandrel Steel Piping
Re-enforced Silicone Couplers
All Necessary Additional Parts For Install
Greddy RS BOV with Flange (BOV Options Available With Different Pricing)
Swap Materials $200.00
Materials Include:
Fuel Injection Line
Coolant Line
Fluids
NGK Spark Plugs
All Clamps
Total S13 Chassis $4625.00 Installed
Total S14 Chassis $4825.00 Installed
Recommended Maintenance Items
OEM Nissan Water Pump $77.49
OEM Nissan Thermostat $89.00
Labour To Install Above $75.00
OEM Nissan Front Main Seal $9.96
Labour To Install Above $37.50
OEM Nissan Rear Main Seal $36.65
OEM Nissan Head To Manifold Gasket $23.07
OEM Nissan Manifold To Turbo Gasket $18.02
OEM Nissan Turbo Extension Pipe Gasket $23.52
Labour To Install Above $150.00
Exedy Stage 2 Clutch $489.95
Machine Flywheel $75.00
Recommended Upgrades To Consider
§ Walbro Fuel Pump
§ Boost Gauge
§ AEM Wideband
§ Gauge Pod
§ Koyo Radiator
§ Flex-A-Lite Electric Fan
§ Boost Tee/Controller
§ Turbo Timer
§ Manifold and Turbo Upgrade
§ Fuel Pressure Regulator
§ Rocker Arm Stoppers
§ Greddy Intake Manifold
§ 3” Turbo Back Exhaust System
§ Oil Catch Can
