KAe. Has trouble starting. 1/6 times does not start. Idle is not steady.
Problem started after I relocated my battery and custom fitted a shorter intake piping. The two tubes that originally connected to the intake are connected and have been checked for vacuum leaks… Only things left unplugged is the hose that to the emissions downpipe box-thing and the air temperture sensor that fits to the air box.
So my question is would be; Does anyone have any thoughts on what could be causing the problem other then a vacuum leak? I was thinking maybe one of the two hoses (smaller of the two) that connect to the intake may not be getting adequate air - i had to use adapter to shrink fit it onto my piping…
