i have a red 90 240 and the sohc engine blew so i got another 90 sohc and just finished installing it it running good but there are a few small problems
when the car is warmed up the idle is still at 1500 rpm and iv adjusted the throttle cable and does not help
i think the car is running rich then engine also shacks alot b4 it warms up
when i drive the car as im going through 1st as soon as i get to 4-5000 rpm it cuts out then i shift into second and it does then same and so on in every gear it wont let me go pased 4-5000 rpm
adjust down your idle to 700-750
then check your timing and your problmes should be solved unless you have a vacume leak.
Also you should of changed your pulgs if you didnt when you put the new motor in.
well for number three it could result in not enough spark or not enough gas… Soo theres a few issues like a fuel filter, fuel pump or wires, coil… A few factors but theres ways to check but a fuel filter is a quick cheap fix and you should try that if you havent changed it before.
But thats my opinion. Before i had an issue where it wouldnt pass 4,000 rpm and it was because i only had 3 outa 4 cylinders working… one of the wires technically exploded on me lol soo id check with your wires/plugs/fuel filter… mayb your injectors… who knows :?:
fuel pump…timing mabey…but tell me this… was the newer motor that you put in idling just fine…becasue if it iwas then dont go screwing with the idle adjustment…becasue thats a half ass way of covering up the problem…
for the cut out related issue im just curious to know does ur speedometre work? if not then thats the problem and u need a new cluster…but thats just what im wondering
