lost power to interior lights,clock and stereo
hey guys i have no clue what is going on but my interior lights, clock and stereo are not working
i believe madchild is having the same problem.
car start? have battery power to other stuff?
check the 75a alternator fuse.
It’s a fuse. That’s all. I had the same problem. Dome lights, chime sound, clock all dead if this fuse is dead. Check over all your fuses and replace as necessary.
check fuses first.
mine peroblem is abit diffent but i say you should check your fuses its should be the 3rd from the bottom on the right side
75a main fuse, green. and i think theres another 30a fuse for all of the interior lights. If not check your relays.
