I usually don’t make build threads before the build is finished, but I figured what the hell. I’m bored.
1989 Toyota Supra 5-speed N/A. I bought it in December of '07 from the original owner since December of '88. Everything was original. 100% rust free. Car spent it’s whole life in Mississippi.
2JZGE from a 199? Lexus SC300
Turbonetics 60-1
440cc injectors
SAFC II in conjunction with an AEM wideband
OEM TT Headgasket with ARP studs
ARP rod bolts
The 2JZGE will be ran off of 7MGTE sensors, ECU, and wiring harness.
The block just came back from the machine shop getting the cylinder walls honed and the deck resurfaced. New rings and bearings are on order from Toyota.
The original 7MGE
The intercooler that will be going in:
My $250 2JZGE
Goods:
Turbo
I will keep updating this thread as the build progresses.
Took the head apart, did some porting and polishing. Installed the oil pan and water pump.
before <> after
Valves are in, now for the buckets, cam shafts, and the best part… to shim the valves.
Buckets, shims, and cams are in.
Shimming is complete, cam gears and timing belt installed.
---------- Post added at 06:18 PM ---------- Previous post was at 06:15 PM ----------
And for those wondering about the stripes on the hood, and why the photos in my intro thread don’t have them, is because I had a front-end collision and was lucky enough to find another white Supra in the scrap yard, but it had the stripes on it. After the engine build is complete, the whole car will get a coat of the original white again.
