all you can hear is the exhaust note,m then when you hit 5 k, it soulnds like a tonne of air just released in the engine bay, alomst like a bov but not as sharp, nd this is while still on gas
perhaps im havng a problem with my bov? its mounted about a foot from the tb, maybe its faulty and releasing air early under load and the charged air is not even getting into the motor then?
Its most likely not your BOV, theres no reason for it to just sudden open if its not seeing any vacuum.
If you have a leak then by all means that could be the issue. Start by fixing the leak and hooking up the O2 as they can cause weird problems like this. You cant diagnose a problem without having everything running right beforehand.
Your taking the vacume source for your bov from the wastgate?
take it from the throtle body teed from the fuel pressure reg then take the car for a rip and see
Mael
upgrade maf… our ca ones are too weak, z32 is my next investment and nistune:) so i can finally drop in my new injectors. i have a very close setup to yours and have felt that same bunny hop at the top of the rpm.
