This is pretty much copy and pasted from the F150 forum I’m a member on. They weren’t exactly helpful so I’ll put it out here now and see if any geniuses can provide some input. Hopefully the tire brothers will have a look at this thread. I had another thread going previously on choosing a new wheel / tire combo.October 5, 2014
I’m at a stop sign here with this little mod and could really use some help / advice. I bought this 2006 F150 FX4 locally, used with about 89K on the clock. It came with some American Racing chromies and I liked them at first but when I decided I wasn’t going to be able to run the rubber much longer I looked at doing a complete wheel / tire swap. The BFG’s on there were the TA/KM’s, and while they looked cool, they were loud and made the truck ride like a shopping cart. With winter coming up I knew it was time for another tire choice.
I looked at a couple different wheels before finally settling on Fuel Revolver’s in 18" flavor. I made the mistake of buying them from 4wheelonline.com and it took the better part of 6 weeks to get the whole debacle they created worked out. I don’t want to get into it too deeply but I ended up buying the correctly sized 4th wheel from another vendor who wasn’t sniffing glue and brain damaged. Word to the wise…DO NOT ORDER FROM THESE MONKEY’S, YOU WILL REGRET IT! After all the BS I finally got my new Goodyear Duratrac’s (same size as the BFG’s 285/70/17 but run a little bigger) from Discount Tire Direct mounted and away I drove. The road noise and ride were much better but once I got on the thruway, that’s when I noticed some shake. Not death wobble bad but annoying from 55-65,70 mph.
So let me condense this down and save some time.
- Took back to my buddy’s shop and rebalanced, traditional balancer. No Change.
- He took them to have them road force balanced at a friend’s shop. No change. (Come to find out he may not have road force balanced them as he prmised.
- I took them to a local tire shop (Dun Tire) who only does tires. Road force balanced again. Balanced out pretty good with readout sheet and all. No change.
- Had varying degree of change with increased tire pressure but nothing major.
- Decided I needed hubcentric rings even though most of the data I’ve found on the interweb says these are lug-centric.
- Found a set on ebay but they were 87.0 mm / 108.0 mm (they needed to be 87.0 / 106.4 but 108.0 was the closest I could find). I figured they might be a little “snug” but turns out that little difference was a lot and no workie.
Rings are my last option to solve this. I did a pretty good amount of searching with no luck. My question is this. The Ford 87.0 mm hub is pretty common and I would think there’s a lot of these wheels out there, so why can’t I seem to find a proper ring?
I don’t have any other explanation that makes sense in my mind. Wheels: New so can’t (shouldn’t) be bent, Tires: balanced, new rubber. What else is there?
Any insight you can offer would be appreciated. I don’t have any more tricks or ideas and I don’t think I can go on with this, especially being the tires are brand new. I just want a smooth ride back again. Thanks in advance.
PS-Just in case anyone is considering buying these wheels, the holes are very “narrow” and impact sockets will not fit, standard chromies will but are close.
November 13, 2014
This was posted 4-6 weeks ago so here’s where I’m at. I remember seeing on the manufacturer’s website these are supposedly lug centric and not hub centric, now I know the difference. Biggest question is this I guess. If my thinking is sound on this, balancing on any balancer that doesn’t have a lug adapter is going to use the hub center bore and although seeming to balance out on the machine, could be wrong when they are mounted on the truck’s lugs.
I also wanted to try the centric rings out but I need to find someone with a lathe who could mount them and shave 2 mil. off the outside diameter. I doubt this would solve the problem but I’m ready to try anything once at this point. This is a web image of what I have. They are a very hard plastic.
What I have also noticed is that the shaking can almost completely disappear at times. My thinking tells me that if both wheels are out of balance, once in awhile they will “sync” and balance / cancel themselves out. I’m really out of ideas and hope someone has a simple solution instead of me speculating in the dark and trying all the wrong ideas. Thanks in advance.
